Wiring suggestions
95cat
Member - Posts: 22
Posted: August 09, 2006 at 9:46 PM / IP Logged
Hi so I recently purchased 2 12" memphis m3 mojos dual 2ohm voice coils rated at 750w rms. I believe they're probaly underrated. The sensitivity at 2.83 volts is 89.89. I`m trying to figure out different ways to wire them, and then purchase the necessary amp/amps.
I`m leaning towards getting a sinlge amp and wiring them in a series to 2ohms. I would wire them to the Memhpis Mojo amp which is 2000x1@2ohms rms power.
Or else I'd try running them seperate to a smaller memphis class D amp, rated at 1100x1@1 ohms?
Which way is the more efficient way to run this setup?
95 Mercury Cougar
Eclipse HU
12" Memphis m3
Memphis 1000.1d
RF Power 6x9
stevdart
Platinum - Posts: 5,816
Posted: August 09, 2006 at 11:47 PM / IP Logged
Wiring suggestions - Last Post -- posted image.
The necessary amplifier to run this pair of subs is a mono amp.  Choose one that is rated to provide RMS power at 2 ohms.  About 1000 watts at 2 ohms should be your goal.  Choose the best quality amplifier that you can afford.
Saturday, May 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
