relay?
demeanor
Copper - Posts: 81
Posted: January 14, 2003 at 9:15 PM / IP Logged
Okay, I have a SPDT switch, and in position 1 I need it to turn relay A on.  I have relays A, B, C that need powered on 2nd position of the switch (on-off-on).  How do I isolate relay A from both  B and C in position 1 when in position 2 they all have the same ground?
I know i should use a diode but i'm kinda hazy as to where, and the way the diode will face.  I only need relay A to be energized or grounded in position 1 but  i need relays A, B, and C to be energized in position 2 of the switch.
Your help and expertise are greatly appreciated!
Thanks in advance for your help.
It's better to ask a "STUPID" question...than to know a "STUPID" answer. :-)
the12volt
Administrator - Posts: 3,955
Posted: January 14, 2003 at 9:34 PM / IP Logged
If you are supplying ground to each relay from the switch, connect the output of the switch just for relay A and the anode side of a 1amp diode to the coil of relay A. Connect the cathode side (side with stripe) of the diode to the output of the switch that also connects to the coils of relays B and C. If you need a diagram, just let me know.
demeanor
Copper - Posts: 81
Posted: January 14, 2003 at 9:45 PM / IP Logged
pleazzze...send me a diagram if you don't mind, thanks.relay? - Last Post -- posted image.
the12volt
Posted: January 14, 2003 at 10:10 PM / IP Logged
Here ya go.
demeanor
Copper - Posts: 81
Posted: January 14, 2003 at 10:13 PM / IP Logged
THANKS !!!!relay? - Last Post -- posted image.  relay? - Last Post -- posted image.
is there a program you use to be able to draw diagrams like this one?? is it available?
the12volt
Posted: January 14, 2003 at 10:29 PM / IP Logged
You're welcome. Believe it or not, I used MS Paint to draw it. :) ....o0(Start>Programs>Accessories>Paint)
Tuesday, May 21, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
