Car alarm choices help me out here.??
Pufferking
Member - Posts: 25
Posted: January 14, 2003 at 9:31 PM / IP Logged
Ok i need some help decideing on a car alarm.Here is what Im looking at i want remote start i would like to add features later on like window rollup.I narrowed down choices to these three.
Can anyone give me the Pro's and Con's of these three choice's how are the transmiter range on these choices.
Viper 550esp
Autopage RS750lcd
Prestige APS996    ??????????
Pufferking
swerks
Copper - Posts: 224
Posted: January 14, 2003 at 10:18 PM / IP Logged
if range is what you are looking for as well as progammable outputs fo future expansion check out the astrostart 3106.  all i can say is awesome!!!
steve sverdahl: installer\owner:
morinville custom carsound&security
edmonton alberta
swerks@shaw.ca
Pufferking
Member - Posts: 25
Posted: January 15, 2003 at 6:38 PM / IP Logged
Ok i just got the viper 550esp will i need anything else when i hook up the alarm.I have a 1992 ford explorer automatic.
I also got two door Actuator's and will be hooking these up also
pufferking
jayts95
Copper - Posts: 150
Posted: January 15, 2003 at 7:07 PM / IP Logged
You will need 2 spdt relays to hook up the actuators.  That should be about it.
Pufferking
Member - Posts: 25
Posted: January 15, 2003 at 7:36 PM / IP Logged
Ok thanks I was reading the installation guide on the back it has a (wiring quick reference guide)I noticed on some of the wire's it has (-)200mA starter relay turn on do i need to hook up a doide to this.
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
