Legacy Series II LA1020 info?
hemanjoyman
Copper - Posts: 77
Posted: August 23, 2006 at 9:59 PM / IP Logged
I have an older Legacy amp, a Legacy Series II LA1020. I can't find any info. on it online anywhere; everytime I input the Legacy LA1020 online, it always brings up a 1000Watt max. model, but mine is an 800Watt model, I guess it must have been updated or something. It is an older amp, about 10 years old, I got it when I was 17 and had no money to buy better stuff.
It says it's an 800Watt max amp, 4 channel. It has two 25A fuses. I know there is no way it can output 800 watts. I'm just wondering if there is any way to figure out how much power it can really output without actually bench testing it.....I don't have the necessary power supply to test it anyway.
Any info would be great.
KarTuneMan
Platinum - Posts: 7,056
Posted: August 24, 2006 at 12:44 AM / IP Logged
Why is it important to know....? It's an entry level (at best) amp. Estimate MAX. 100 watts per 10 amps of fusing, unless someone changed the fuses. This is a very NON scientific way of guestimating power output. Again....does it really matter?
hemanjoyman
Copper - Posts: 77
Posted: August 24, 2006 at 12:57 AM / IP Logged
Yes, it matters because I want to know. It doesn't matter to me that it's an entry level amp or worse. If you don't know, that's fine, you don't have to reply either. There is no need to be condescending.
haemphyst
Platinum - Posts: 5,059
Posted: August 24, 2006 at 9:10 AM / IP Logged
50A*14.4V=720 watts INPUT
720W*.6 (peak efficiency of class A/B amplifier)=432 watts OUT
Best case scenario, that amp is 432 watts RMS, or 216WPC. 800 watts IS a max rating.
hemanjoyman
Copper - Posts: 77
Posted: August 24, 2006 at 9:51 AM / IP Logged
Thanks haemphyst, I appreciate the help.
Flakman
Copper - Posts: 365
Posted: August 24, 2006 at 9:58 AM / IP Logged
Haem, riddle me this. I see about 90% of amps and subs rate their power at X Watts RMS and 2X Watts Max. RMS is .707, not .5 of peak. Whiskey, Tango, Foxtrot...over!
The Flakman
I feel strange. I have deja vu and amnesia at the same time.
John | Manteca, CA
KarTuneMan
Posted: August 24, 2006 at 11:23 AM / IP Logged
I truly did NOT mean to sound like that....PLEASE accept my apologies. I should have said to you, that I don't know the "formula" for figuring this out...but someone here does. Again, Im sorry for coming off the way I did.
hemanjoyman
Copper - Posts: 77
Posted: August 24, 2006 at 3:53 PM / IP Logged
Don't worry about it KarTuneMan, maybe I took it the wrong way.
It's all good.
KarTuneMan
Posted: August 25, 2006 at 12:38 AM / IP Logged
Cool Man......thank you!
