Sub/RCA Problems
caps12
Posted: August 24, 2006 at 10:49 PM / IP Logged
Hey guys, Im glad to be a new member of the forums,but down to my problem. I have a 1994 Toyota pickup, and i have installed 2 Kicker CVR's with a 880.2 Soundstream Xstream amp.
They worked great until yesterday, i was making my wires cleaner to my amp and after i did i hooked it back up JUST LIKE I HAD IT. And to my suprise only one sub was hitting.
I have changed around the RCA cables several times but it seems as if the left channel RCA cable does nothing, but i know both channels and both inputs on my amp work cause i didnt do anything wrong to mess them up and i have tested them. Any information, or ways to fix it by you guys would be very much appreciated.
I was thinkin maybe it was the wires from inside the box cause like today i was ridin to school, and it started to hit, but then it would quit and then hit again like off and on. now its just not hittin. Thanks guys in advanced
caps12
Posted: August 24, 2006 at 10:56 PM / IP Logged
damn you guys answer fast :) and thanks man for the info will do, ill keep you guys updated on what i find
rudydapimp
Copper - Posts: 390
Posted: August 25, 2006 at 3:56 PM / IP Logged
did you blow a voice coil onthe suspect sub????  use your dmm and check the vioce coil for the proper resistance.
caps12
Posted: August 26, 2006 at 4:03 PM / IP Logged
I found out what it was, i checked the unworking sub and it seems that one of the wires running from one of the voice coils that goes to the motor come off so i saudered it back on and it works great
