How much polyfill is too much?
qnretail
Member - Posts: 32
Posted: August 29, 2006 at 10:22 PM / IP Logged
BassBox 6 Pro has a feature that will factor the amount of polyfill used in an enclosure into the overall 'perceived' box volume. I don't know how accurate it is, but you can input the general amount of polyfill that you plan to use inside the enclosure and it will adjust the box volume and tuning frequency to allow you to better determine how much is needed.
Oh, and it also takes into consideration the efficiency of the box construction.. or as I call it, the 'crap factor.'
Don't you love the marvels of modern technology? I can't imagine a world where we can't predict the exactly level of crap that we will get to listen to as a direct result of half-assing our speaker enclosure projects.
2 x DD9515f's, Digital Designs Z1 amplifier
stevdart
Platinum - Posts: 5,816
Posted: August 29, 2006 at 11:06 PM / IP Logged
The only thing is, those fart sounds of a split seam in a crappy box don't show up as much in a graph as they do in real life!
5150azn
Silver - Posts: 584
Posted: August 30, 2006 at 1:24 PM / IP Logged
When your wandering isles of the local sewing supply store for the best deal on polyfill.... you're using too much polyfill
Tell the Snap-On guy I'm not here!
