2003 sierra 457g
xtremej
Gold - Posts: 1,440
Posted: August 30, 2006 at 12:37 PM / IP Logged
I put a remote start on this truck and every now and then after remote started when you hop in and put the key in cycle it forward/hit the brake it will say the door is ajar although it is not. I haven't seen this one yet, anybody got a fic for it.
iskidoo
Silver - Posts: 1,048
Posted: August 30, 2006 at 2:37 PM / IP Logged
try a new bypass.
Steve G
xtremej
Gold - Posts: 1,440
Posted: August 30, 2006 at 2:42 PM / IP Logged
I did this 3 times 3 new bypasses, same thing....
iskidoo
Posted: August 30, 2006 at 2:46 PM / IP Logged
Other than swapping the brain or double checking the trigger wire to make sure that some of the copper strands didn't snap and make a weak connection, I have no idea.
Steve G
iskidoo
Posted: August 30, 2006 at 2:48 PM / IP Logged
Has DEI support heard of this problem with this particular vehicle. May be a software bug in that bypass version release.
Steve G
xtremej
Gold - Posts: 1,440
Posted: August 30, 2006 at 2:50 PM / IP Logged
This may sound dumb but by trigger wires do you mean the connections going to the door triggers. If so according to dei tech I was not supposed to hook them up.
iskidoo
I'd try hardwiring the door trigger and leave the rest of the wires running through the bypass. If it corrects it, make a note in your wiring daigrams and give a heads up to Directed.
Steve G
xtremej
Gold - Posts: 1,440
Posted: August 30, 2006 at 2:55 PM / IP Logged
I have it hooked as such blue/white to white purple -status from remote start, green to green wire from remote start, blue to blue, I don't have anything hooked to the door triggers from the remtoe start or the 457g....I've called directed twice and got 2 different answers the first guy said not to hook to the door triggers an 2 wire it the way it is now. I did that, still could get the drivers door ajar to trigger sometime, I called back and the 2nd tech blamed the ultra starter (of course) I have tried changing the brains just for kicks.
xtremej
Gold - Posts: 1,440
Posted: August 30, 2006 at 2:57 PM / IP Logged
Oh and yes the first tech said they had heard of it happening with some of  the 457g. Nightmare, maybe I'll have to switch it out for the gmdl-bp.
JWorm
Platinum - Posts: 2,208
Posted: August 30, 2006 at 6:00 PM / IP Logged
I have heard of this happening many times with the 457G. The techs at DEI know about it. Switch it out for a GMDL-BP and your problems will go away.
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
