BMW Wiring 325
akennedy89
Posted: August 30, 2006 at 11:19 PM / IP Logged
Can anyone help me install a headunit in a 1995 BMW 325ci. I am doing it for my friend and came across a lot of problems. I got the headunit powerd but no sound is going to the speakers, I believe becuase there is an amp under the rear seat that is not getting powerd. Can someone help me either power this or just bypass this, or tell me why this isnt working. It woudl be helpful to see a wiring diagram of the entire system too if anyone has it.
Thanks,
Alex
KarTuneMan
Platinum - Posts: 7,056
Posted: August 31, 2006 at 12:19 AM / IP Logged
The 6 speaker system looks fairly easy...the 10 speaker system has an amp. There should be a white wire in the harness. This is the amp trigger.
akennedy89
Posted: August 31, 2006 at 3:15 PM / IP Logged
White with a red or black line? and there is also a huge black cable that goes to a 10 prong square female plug that I have no idea what it is.
Thanks for the reply, any help is appreciated.
Alex
akennedy89
Posted: August 31, 2006 at 3:23 PM / IP Logged
^^^ And this amp can be wired into a new headunit?
I have done probably 10 stereos in my life no problem, and this BMW is being a bi*ch.
