Problem w/ Kenwood Excelon Stereo in 2002 Tahoe
act1713
Posted: January 16, 2003 at 4:00 PM / IP Logged
I have a 2002 Z71 Tahoe that did not have a Bose stereo system in it.  I recently had a Kenwood Excelon KDC-X859 and an amp and sub installed.  The amp is only running the sub.  The problem is that when I initially start the car, all I hear is bass coming from the sub.  I am not hearing any music come out of the panel speakers.  I have to shut the car off and restart it for the speakers to come on.  Anyone have any ideas? Help!
brianh
Silver - Posts: 518
Posted: January 16, 2003 at 6:23 PM / IP Logged
You might want to check your ground wire.  Dont use the factory ground wire in the harness run it to a good ground somewhere in the dash.The kick panels is also a good spot to ground stuff.  Brian
act1713
Posted: January 17, 2003 at 8:18 AM / IP Logged
Thanks, I'll try that.
Does anyone know if I may have to bypass any factory amps also?
I was also told that the stereo power lead of the Tahoes pulses or surges, which may cause this too.  Does anyone know if this is true?
auex
Platinum - Posts: 5,041
Posted: January 17, 2003 at 8:06 PM / IP Logged
Do you have onstar?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
act1713
Posted: January 18, 2003 at 7:27 PM / IP Logged
Yes, I have onstar, but I had it bypassed.
auex
Posted: January 18, 2003 at 8:18 PM / IP Logged
The vehicles that I have seen with onstar, most have a factory amplifier.  If you have an actual center console then pull out the cup holders and see if you have more than about 8 wires.  If there are a couple of large black plugs then there is a factory amplifier and these are the wires for it.  I would rewire the speakers directly to the deck.
act1713
Posted: January 19, 2003 at 2:06 PM / IP Logged
Thanks for the tip.  I did find out there is a factory amp in my tahoe.  Does anyone know where it is located?  Is there a wiring diagram that I can use to help me locate and bypass the factory amp?
