06 tundra
qdaddy
Copper - Posts: 133
Posted: September 01, 2006 at 9:56 PM / IP Logged
door locks
swamprat323
Gold - Posts: 1,335
Posted: September 01, 2006 at 10:06 PM / IP Logged
Power Unlock          BLUE/RED          (-)          IN HARNESS IN DRIVERS KICKPANEL
               THIS WIRE REQUIRES A DOUBLE PULSE TO UNLOCK
     PowerLock          WHITE/ GREEN          (-)          IN HARNESS IN DRIVERS KICKPANEL
               (CAN ALSO BE WHITE/ GREEN (-) OR GREEN/ BLACK (-) IN THE DRIVERS KICK PANEL)
if dont have locks and need to add i belive they are cable type sysem
Chris Luongo
Platinum - Posts: 3,746
Posted: September 02, 2006 at 10:28 AM / IP Logged
What body style?
The two-door, and two-door extended cab, have regular-style locks that are easily found in the driver's kick panel......use the instructions above.
If it's a true 4-door truck, with four real doors like a car, the locks are far more difficult, and a special interface must be performed inside the driver's door at the power window switch............do a search for how to do locks on a Sequoia or Avalon; it is the same.
There is also a piece from bypasskit.com that'll do the locks for you; it is up to you whether the time-saving is worth the extra cost.
Tuesday, February 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
