2003 Murano Parking light wire location
thomasfx10
Member - Posts: 11
Posted: September 05, 2006 at 1:22 PM / IP Logged
I am installing an alarm with remote start (APS997) in my 2003 Murano and cannot seem to locate the parking light wire that I need to splice into.   I searched the post and it states driver side kick panel up high in the back.   They state it is a red and blue wire.  I was hoping someone could be more specific.  Like right side by the so and so or middle in.   There are a lot of wire under there.  I even downloaded the Nissan service manual and still have trouble located it.   Can I get this from the ECM?   Also ... Where is the tach wire located?  Do I need to go to the coil in the engine compartment?
Any help would be appreciated.   Thanks
Thomas
dea,can
Copper - Posts: 284
Posted: September 05, 2006 at 1:51 PM / IP Logged
PARKING LIGHTS ( + ) RED / BLUE (+)  IN DRIVERS KICK PANEL, HARNESS to REAR of VEHICLE
any wire not red or blue ignition coil
dragon
thomasfx10
Member - Posts: 11
Posted: September 05, 2006 at 3:22 PM / IP Logged
Dragon,  maybe this is where the confusion is.  When I hear kick panel I am thinking below the driver side dash.   Are you saying it is in the rear of the vehical?    Are there any wires under the dash the I can tap into?    Not sure what you mean when you say any wire not red or blue ignition coil for the tach.   So I do have to go to the coil in the engine carpartment?  Thanks
Thomas
JWorm
Platinum - Posts: 2,208
Posted: September 05, 2006 at 6:18 PM / IP Logged
There is a harness that runs to the back of the car down the drivers side. Look in there. I hope you are testing with a meter and not just going off of location.
KarTuneMan
Platinum - Posts: 7,056
Posted: September 05, 2006 at 7:37 PM / IP Logged
Theres a grey plug up high (by your left foot) (more like your left foot's toes) next to the E-brake. RED / blue as stated!
thomasfx10
Member - Posts: 11
Posted: September 06, 2006 at 8:34 AM / IP Logged
Thanks!
Thomas
Saturday, April 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
