Sub not loud enough, components overloaded
wxxyz
Member - Posts: 20
Posted: January 17, 2003 at 12:33 AM / IP Logged
hey...
I'm running 2 way 4 inches in the front, 2 way 6 inches in the rear. I have a 12 inch sub powered by a 200watt amp....the gain is cranked.
With the rear speakers disconnected and the fade to the back, the sub is plenty loud. How do I get this same volume from the sub without over powering my rear speakers?
wvsquirrel
Gold - Posts: 1,237
Posted: January 17, 2003 at 12:45 AM / IP Logged
Does your head unit have RCA pre-outs?  Judging by what you've said, you have the signal from the amp comming directly off the rear speaker wires (high level input into the amp).  Keeping this configuration, you will alyaws get less volume if you put the fade to the middle (Front and Rear).  However, you should not have a problem with the rear speakers by reconnecting them and adjusting the fade.  The amp will pull what it needs from the high level inputs, and send the signal to the sub.  The rear speakers will get what they need as well.  If the amp has a built in crossover, then you should only get bass out of the sub.  Adjusting the bass level from the headunit will directly affect the sub's volume as well.
If your headunit has RCA pre-outs, and the amp is equiped for RCA inputs, then use RCA's to connect to the amp instead of the rear speaker wires.
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
wxxyz
Member - Posts: 20
Posted: January 17, 2003 at 11:30 AM / IP Logged
sorry, I should've specified...I am using the rca oputputs, theres both a rear and front pre-out, and when I put them on the rear pre-out, with no rear speakers, the sub pounded. (the amp has a built in low-pass crossover)
Maybe I need to put a high pass crossover in-line with the rear speakers so they don't try producing the low frequencies?
swerks
Copper - Posts: 224
Posted: January 17, 2003 at 2:38 PM / IP Logged
what kind of hu is it
bberman1
Gold - Posts: 2,314
Posted: January 17, 2003 at 6:50 PM / IP Logged
use a 3 way electronic crossover such as this one.http:///.com/dll?ViewItem&item=3001458315&category=14931  it will then split your 2 inputs and give you a rca output for the sub as well as allow you to adjust the way things sound.
SnomanF150
Silver - Posts: 269
Posted: January 17, 2003 at 9:56 PM / IP Logged
Radio power on the high end or an amp on the high?  If amp on the high, turn the gain down on the high amp
George
David's Car Stereo
Baton Rouge, LA
wxxyz
Member - Posts: 20
Posted: January 18, 2003 at 12:51 PM / IP Logged
It's a Sony head unit, mp450x.
Snomanf150: Amp is on the LOW end...I need more bass captain!
The Crossover thing would probably work, I was hoping for a cheaper fix...perhaps free!?
