Infinity Amp Wiring
mikekinard
Posted: January 17, 2003 at 2:13 PM / IP Logged
Does anybody know where i can find a wiring diagram for the factory infinity amp that comes in a 1998 Chrystler Sebing LXi and also instructions on how to remove the dash board and door panels thanks.
Mike
ViperATC5
Copper - Posts: 202
Posted: January 17, 2003 at 7:24 PM / IP Logged
If you are trying to install a radio into this vehicle you can play directly into the infinity system simply by hooking up the remote turn on lead on your radio to the harness for the vehicle - The dash bezel for this car pulls right off (there may be a screw or two - just take a look, they arent hidden or anything) and the doors are held on with clips, just look for screws holding the handle in and then remove the doors using a panel tool to pry the clips without breaking them.  I do believe that the grills that cover the 6x9s in the front doors just pull off so you may not even have to remove the door if you are trying to change the speakers
Friday, December 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
