autopage 750lcd vs marksman m10
weiweiwei
Copper - Posts: 59
Posted: January 18, 2003 at 1:00 PM / IP Logged
marksman m10
http://www.magnadyne.com/index.cfm?MasterAction=Item&InvMasID=8868&Web_Catid=136
autopage 750lcd
http://www.autopageusa.com/autopageusars750.htm
these look the same, and the features are pretty much identical.  anybody know if these are actuallly the same product just diff name?  Or did one of the company here copy the other one?  i read a site that says the marksman m10 has warn away chirps ( proximity ) ??
jrilla
Gold - Posts: 1,498
Posted: January 18, 2003 at 5:41 PM / IP Logged
Same thing.  Also the same as the Commando FM-760 here:
http://www.commandocaralarms.com/itemdetails.asp?Productid=1185
The Commando is cheaper since the temp sensor and Knock sensors are optional.
J Rilla
Owner/Installer
weiweiwei
Copper - Posts: 59
Posted: January 18, 2003 at 8:30 PM / IP Logged
does the marksman come with the temp and knock sensor? or are they optional as well?
does the marksman come with SIS dual stage shock sensor w/ glass sensor?
jrilla
Gold - Posts: 1,498
Posted: January 18, 2003 at 8:53 PM / IP Logged
I am pretty sure they come standard.  The knock sensor is not it is cracked up to be.  I wish it was like my last 2 way unit where you just pressed the program switch at any time and it would page the transmitter.  With this one the unit has to be armed.
J Rilla
Owner/Installer
weiweiwei
Copper - Posts: 59
Posted: January 18, 2003 at 11:00 PM / IP Logged
well the autopage u have to arm it by hodling the lock key for a few seconds then it will arm in the knocking mode
securinu
Silver - Posts: 772
Posted: January 19, 2003 at 10:49 AM / IP Logged
marksman does not come with either sensor but they are cheap . if you want one  email me for a price on sensors and unit itself.
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
