Trunk Solenoid trigger hookup
Raymond4646
Copper - Posts: 121
Posted: September 19, 2006 at 3:56 PM / IP Logged
I want to trigger my 522t trunk solenoid to open the trunk via my -250ma Compustar trunk output.  How should I wire up the relay to make this work.  Do I need 2 relays one to boost the signal of the compustar output and the other to open/close the ground of the solenoid?  Thanks for any assistance.
captainzab
Silver - Posts: 606
Posted: September 19, 2006 at 4:03 PM / IP Logged
off the trunk poper, theres 2 wires,
run the red wire up to the compustar and ground the ground somewhere back there next to popper
wire relay like this:
85 & 87 Fused 12v
86 200ma output wire of compustar
30- output to the popper
Note: You Always Dont Get What You Pay For.
Raymond4646
Copper - Posts: 121
Posted: September 20, 2006 at 6:04 PM / IP Logged
85 & 87 Fused 12v
When you say run the red wire up to the compustar, are you suggesting just tagging 12volts at the compustar while providing a switch in series?
ohnelly1978
Member - Posts: 20
Posted: September 20, 2006 at 7:20 PM / IP Logged
no run the red wire up to the 30 of the relay
ohNelly!
Raymond4646
Copper - Posts: 121
Posted: September 20, 2006 at 8:11 PM / IP Logged
Sorry, I'm not following you with that post.  I have the -250ma trigger wire in my trunk along with a fused 12volt red wire.  I understand the how to connect the relay, as it gives out a negative output.  I however dont understand how giving terminal 30 (negative output) a positive voltage will work.  Can you explain.
bellsracer
Silver - Posts: 703
Posted: September 20, 2006 at 8:36 PM / IP Logged
He means the positive wire on the popper. Not all cars use red for it. Grand Marquis usually use a purple wire yellow stripe for the popper's positive wire for example.
Good Luck!
auex
Platinum - Posts: 5,041
Posted: September 20, 2006 at 8:40 PM / IP Logged
Read the section on relays. You will find your answer there. Relays output depends on what you use as an input. Either way you have your answer in this thread and if you need to understand it then it is in the relay section on the left.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Raymond4646
Copper - Posts: 121
Posted: September 20, 2006 at 9:37 PM / IP Logged
I just want to ensure I don't burn out an aux channel.
85 & 87 Fused 12v
86 250ma output wire of compustar
then I need to give the popper ground and 12 volts, so the one popper terminal will get the output from 30 since it's a negative output and the other will get constant 12volts correct?  Thank you very much.
captainzab
Silver - Posts: 606
Posted: September 20, 2006 at 10:34 PM / IP Logged
Trunk Solenoid trigger hookup -- posted image.
Raymond4646
Copper - Posts: 121
Posted: September 21, 2006 at 5:31 PM / IP Logged
Thank you for the illustration.  I was just concerned about burning out the weak 250ma output of the comustar.
