Door lock 2003 PT cruiser
evnldr_gt
Posted: September 25, 2006 at 7:32 PM / IP Logged
i have a 2003 PT cruiser GT
I have the 7.2K and 3K resistors ..  i have been working on this for a day... i have tried it with and without a DEI relay pack 451 i think..
anybody have a lay out of how this works ... i am pulling my hair out here... i have the resistors dioded as in the Door lock  2003 PT cruiser -- posted image.
captainzab
Silver - Posts: 606
Posted: September 25, 2006 at 10:04 PM / IP Logged
You need the 451m. (or 2 relays)
Because 200ma is not enough, you need a full amperage.
Try the 451m again.
Purp (fused) wire- ground
GREEN/ black- lock output through proper resistor
Blue/Black- unlock output through proper resistor
http://64.85.6.129/extrainfo/diagrams/4623_PT-CRUISER_CHRYSLER%20PT%20CRUISER%201%20WIRE%20JBS%20UNITS.pdf
NOTE *1 This vehicle uses a 1-Wire Door Locking System, LOCK requires a (-)Negative thru a 3000 Ohm Resistor and UNLOCK, requires a (-)Negative thru a 7200 Ohm Resistor, and requires a DOUBLE PULSE to UNLOCK. Some unit also require 2 extra relays Part #775, to connect, See DIAGRAM
Note: You Always Dont Get What You Pay For.
evnldr_gt
Posted: September 25, 2006 at 10:40 PM / IP Logged
So nothing on the 451 is connected but the purple?  no power?
captainzab
Silver - Posts: 606
Posted: September 25, 2006 at 10:49 PM / IP Logged
captainzab wrote:
Try the 451m again.
plug the 3pin harness into the alarm brain.
The other wires on the 451m. u only need 3 wires
purp (input)
GREEN/ black lock output
blue/black unlock output
Cut and tape the brown and white wire. (not used)
evnldr_gt
Posted: September 26, 2006 at 6:33 PM / IP Logged
WHOO HOOO
Worked Im sure somebody else will find this usefull because i for the life of me could not find the 451M wire guid for this..
nipplz
Member - Posts: 24
Posted: September 26, 2006 at 10:59 PM / IP Logged
i have always had good luck with using the standard voltage out of the brain but i lower the resistance of the resistors. the module has a small amount of resistance.  and i never use diodes except on the 06 hyundia tiberon with their goofy set up.
