2001 E-Class E270 alarm wiring
Welcome Guest :)
demofast
Member -
Posted: September 26, 2006 at 10:18 AM / IP Logged
i need alarm's wiring information.
thanks for advice
shaggy12volt
Copper -
Posted: September 26, 2006 at 12:20 PM / IP Logged
| 12volts | red | + | ignition harness | | Starter | purple | + | ignition harness | | Ignition | pink/red | + | ignition harness | | Power Lock | BLACK/ brown | - | PSE control module | | Notes: These are the trunk key cylinder wires. Meter wires while turning the key in the trunk to lock and unlock the doors.The PSE (Pneumatic System Equipment) control module is under the rear seat on the passenger side. | | Power Unlock | blue/green | - | PSE control module | | Notes: These are the trunk key cylinder wires. Meter wires while turning the key in the trunk to lock and unlock the doors.The PSE (Pneumatic System Equipment) control module is under the rear seat on the passenger side. | | Lock Motor | | | | | Unlock Motor | | | | | Disarm Defeat | | | | | Parking Lights+ | gry/blk (L), gry/red (R) | + | illumination control mod | | Notes: The illumination control module is part of the headlight switch. The parking lights and headlights must be relay isolated from the control module. | | Parking Lights- | | | | | Hazards | | | | | Turn Signal(L) | | | | | Turn Signal(R) | | | | | Door Trigger | | - | PSE control module | | Notes: The LF door trigger is BROWN / gray, the RF door trigger is BROWN / blue, the LR door trigger is BROWN / green, and the RR door trigger is BROWN / purple. Use all four and diode isolate each.The PSE (Pneumatic System Equipment) control module is under the rear seat on the passenger side. | | Dome Supervision | comes on with unlock | | | | Trunk/Hatch Pin | BROWN / yellow | - | PSE control module | | Notes: The PSE (Pneumatic System Equipment) control module is under the rear seat on the passenger side. | | Hood Pin | BROWN / red | - | PSE control module | | Notes: The PSE (Pneumatic System Equipment) control module is under the rear seat on the passenger side. | | Trunk/Hatch Release | BROWN / white | - | release switch or PSE | | Notes: The PSE (Pneumatic System Equipment) control module is under the rear seat on the passenger side. | | Power Sliding Door | N/A | | | | Factory Alarm Arm | arms with lock | | | | Factory Alarm Disarm | disarms with unlock | | | | Disarm No Unlock | | | | | Tachometer | NOT blk/yel or blk/grn | ac | any ignition coil | | Horn Trigger | yellow/red | + | horn | | Memory Seat 1 | | | | | Memory Seat 2 | | | | | Memory Seat 3 | | | |
| Interface Module: | Category:Immobilizer Bypass | Required:Yes | Type:Transponder | | Part #: 556UW | | Alternate Part1 #: DesignTech 20402 | | Alternate Part2 #: DesignTech 29402 | | Notes: Only works on vehicles with switchblade keys. Vehicles with the Smart Key, a bypass is not available at this time. |
The Shagmaster
1999 Chevy Suburban 15" lift sittn on 22's sets 7'5"
1992 Chevy Astro Van all Bagged out Dubbed THE SUICIDER
Installing for over 18 years Looking for empolyment NOW send PM for resum
Sunday, April 19, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
