Clifford Matrix10.5X in 05 F-150
mike12volt
Copper - Posts: 98
Posted: September 29, 2006 at 9:07 PM / IP Logged
Is it common or a problem with Clifford Matrix 10.5X in 04 and up in F-150's and Expeditions to chirp twice when arming? In the manual it specified that it is bypassing a sensor then then monitors normally.
I've gone back to the install. place twice to reprogramm
the alarm, and no results. The alarm will chirp once once in a while, but most of the time twice, one seccond in between.
Any suggestions?
KarTuneMan
Platinum - Posts: 7,056
Posted: September 29, 2006 at 11:02 PM / IP Logged
Does that not mean that you haven't programmed the unit to disreguard the dome light staying on for a bit after you close the door?
mike12volt
Copper - Posts: 98
Posted: September 30, 2006 at 11:58 AM / IP Logged
My alarm was installed and programmed at Car Toys store.
The only literature I received was the manual. There is nothing in it about programming the dome light delay.
If any of you have any info. how to, It will be greatly appreciated.
