remote start in a 2006 dodge ram 1500
kai211
Member - Posts: 12
Posted: October 02, 2006 at 8:19 PM / IP Logged
hello just wondering if this car is actually hard to do is there alot of wiring to be done....
Thats SIK!!!!
shaggy12volt
Copper - Posts: 164
Posted: October 02, 2006 at 8:26 PM / IP Logged
not that bad if you know what your doing
WIRING INFORMATION - DODGE / RAM PICKUP / 2006 / Remote Start
12volts lt. blue/red (2A)  +  ignition harness
Starter dk. GREEN/ YELLOW  +  ign harn or starter button (SRT-10)
Second Starter PURPLE / brown  -  ignition harness
Notes: The second starter wire is negative trigger thru an 180 ohm resistor. MUST use a relay. Refer to DirectFax document 1084 for wiring information.
Ignition pink/white  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory same as second starter wire  -  ignition harness
Notes: The accessory wire is negative trigger thru a 610 ohm resistor. MUST use a relay. Refer to DirectFax document 1084 for wiring information.
Second Accessory N/A
Keysense N/A
Power Lock PURPLE / dk. green  -  DKP or cluster, sml gry plug, pin 3
Notes: Lock is negative trigger thru an 820 ohm resistor. Unlock is negative trigger thru a 330 ohm resistor. MUST use relays.
Can also use Directed 456L interface module.
Power Unlock same as power lock wire
Lock Motor lt. green  5wi DKP or cluster, white plug, pin 10
Unlock Motor tan/lt. green  5wi DKP or cluster, white plug, pin 1
Parking Lights+ WHITE/ yel (L), WHITE/ gray (R)  +  harness at top of driver fender
Parking Lights- WHITE/ lt. green  -  sw or cluster, sml gry plug, pin 5
Notes: Parking lights are negative trigger thru a 1130 ohm resistor. MUST use a relay.
Hazards WHITE/ orange  -  sw or cluster, sml gry plug, pin 8
Notes: Hazards are negative trigger thru a 120 ohm resistor. MUST use a relay.
Turn Signal(L) wht/lt grn (F), wht/dk grn (R) +  harness at top of driver fender
Turn Signal(R) WHITE/ tan (F), WHITE/ yel (R)  +  harness at top of driver fender
Reverse Light WHITE/ lt. green  +  harness at top of driver fender
Door Trigger see notes  -  each kick or cluster, lrg gray plug
Notes: The LF door is purple in pin 1. The RF door is PURPLE / white in pin 4. The LR door is PURPLE / orange or PURPLE / gray in pin 2. The RR door is purple / YELLOW or tan / YELLOW in pin 3. Use all four wires and diode isolate each wire from each other and the instrument cluster. See DirectFax document 1076 for wiring information.
Dome Supervision yellow/lt. blue  +  A pillar or cluster, wht plg, pin 21
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm factory remote only
Factory Alarm Disarm factory remote only
Disarm No Unlock with ignition and Sentry Key
Tachometer dk. blue/gray  ac  PCM, BLACK/ orange plug, pin 34
Notes: The PCM is on the passenger side firewall. The BLACK/ orange plug is the second plug down from the top.
On SRT-10 models, the tach wire is in the top black plug, pin 18.
On diesel models, the tach wire is at the ECM on the lower driver side of the engine, front 60 pin plug, pin 24, or at the camshaft position sensor just left of the ECM, in a 3 pin plug.
On gas models, can also go to any ignition coil or fuel injector and use the wire that is NOT BROWN / white.
Wait to start see DirectFax document 1091
Notes: On the remote start, make sure to program the Accessory State During Wait To Start to ON.
Brake Wire WHITE/ tan  +  brake pedal switch
Parking Brake dk. GREEN / WHITE  -  sw or cluster, lrg gry plug, pin 22
Horn Trigger dk. GREEN/ purple  -  sw or cluster, lrg gry plug, pin 14
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
remote start in a 2006 dodge ram 1500 - Last Post -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Sentry Key
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes: Standard on all models except the ST.
Door Lock Interface
Required:
Yes
Type:
Multiplex
Part #: 456LW
Notes:
Smart Starter Kill Relays: Not Available
The Shagmaster
1999 Chevy Suburban 15" lift sittn on 22's sets 7'5"
1992 Chevy Astro Van all Bagged out Dubbed THE SUICIDER
Installing for over 18 years Looking for empolyment NOW send PM for resum
brcidd
Copper - Posts: 274
Posted: October 03, 2006 at 2:12 PM / IP Logged
Last Dodge ram I did was 2 '05s- and soon found out the OEM design does not use a high blower motor relay- pull all that current through the ignition wires- and thus your remote starter box- if the blower is on high- you get all those amps through the R/S box- and I had a unit melt down because of it- and it actually caused the starter relay to energize and wear out the vehicle starter- what a mess- Dodge actually has had melt downs of their ignition wires- when no R/S is installed- so now a R/S really takes the blame when this happens-- so to fix- I wired 40 amp relays into the circuit- to keep the blower volts out of the brain box....and vowed not to do any more Dodge Rams......Go get a wiring diagram of the vehicle and study the circuit before this install to decide what to do- .....just my experience with it.......
Brcidd - Engineer That Does Remote Starter Installs on the side.
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
