escalade 2003
Dank
Posted: January 20, 2003 at 2:05 PM / IP Logged
I put in a crimestopper remote start in a 2003 escalade and it seemed to work fine.. but after the vehicle sets for maybe 5 to 6 hours when u try to remote start it the alarm will go off maybe 4 out of 10 atempts.. any ideas??? I have the right wires i think to disarm the factory alarm on start but it jus doesn't seems to work right all the time.
Nick Johnson
Member - Posts: 9
Posted: January 24, 2003 at 2:34 PM / IP Logged
Try calling Tech Support at Crimestopper.  Some Tech Support is very helpfull, while others are just short tempered.  Did you tap into the factory alarm wires using "T" taps?  If you did, that may be the problem.  "T" taps are great little time savers,  but I've had problems with them being too loose to make a good connection.
Nick Johnson
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
