Removing 02 quad cab stereo
ram_rod
Posted: October 08, 2006 at 11:57 PM / IP Logged
This is probably a easy answer for most, but how do you take out the stereo for the 02 quad cab 1500? I'm trying to take off the trim around the radio. Thanks
Platinum - Posts: 13,725
Posted: October 09, 2006 at 10:33 AM / IP Logged
     There is a hook on the lower right section of the dash piece you are trying to remove      above the hook there is a single phillips screw.    remove that    then grab the piece and pull toward you     it may seem as though you are going to break things but have no worries.
Wednesday, March 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
