help me on starting off?
Eastsydesfynest
Posted: January 21, 2003 at 9:27 AM / IP Logged
I need to know what are the main basic tools needed to build sub enclosures?
gmanbug
Posted: January 21, 2003 at 6:53 PM / IP Logged
  All you need is some MDF(wood), fiberglass mat cloth, resin, MEKP(hardener), and imagination.
SnomanF150
Silver - Posts: 269
Posted: January 21, 2003 at 8:28 PM / IP Logged
strechable trunk liner or a fleese type material.. I like the fleese.. it wets out a lot easier.. but trunk liner will be stronger.. strech this over your project and it will give you all the cool shapes and curves..
George
David's Car Stereo
Baton Rouge, LA
auex
Platinum - Posts: 5,041
Posted: January 21, 2003 at 8:40 PM / IP Logged
As for the basics, you just need woodworking tools and alot of cheap brushes.  You will also need an assortment of sandpaper.  Also you should have a good poweRED / air sander.  This will save you alot of time and alot muscle fatigue.  Fleese is awesome for enclosures, just soak it good on the first application.  My tip is don't put the back of the box on until you do a couple of layers of glass, then pour some resin into the edge that you glassed to seal it and make it stronger.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
audiomechanic
Silver - Posts: 388
Posted: January 22, 2003 at 10:17 PM / IP Logged
raw resin(no mat or cloth) is really weak.....the strength is in the mat.....I presonally prefer to use the trunk liner better, the reason being that there are less balled up pieces of material to sand down, sand it quick with some 80 grit and your good. plus i have had more problems with the fleece warping than the trunk liner.....but everyone has a preference to what they like and there is really no 100% right way to do things it's all what you feel comfortable using......installguy509
