2004 eclipse remote start
jraguilar
Posted: October 13, 2006 at 1:29 PM / IP Logged
am puting a viper alarm on my eclipse and am looking for the wiring colors.. thanks
jraguilar
supra psych
Member - Posts: 7
Posted: October 13, 2006 at 7:00 PM / IP Logged
What year is it? The eclipse has been around for some time and wire colors have most likely changed over the years.
supra psych
Member - Posts: 7
Posted: October 13, 2006 at 7:05 PM / IP Logged
Sorry, I didn't see the year in the title. Hope this helps. It's for a 2004 eclipse remote start. Good luck.
12volts WHITE/ red (40A)   +   ignition harness
Starter BLACK/ red   +   ignition harness
Second Starter N/A
Ignition green   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory blue/red   +   ignition harness
Second Accessory blue/black   +   ignition harness
Keysense blue/red      ignition harness
Notes: This wire rests at ground, and goes to an open circuit when the key is inserted into the ignition cylinder.
Power Lock purple   -   pin 33 at ETACS ECU
Notes: The ETACS ECU is attached to the back of the fuse box.
Power Unlock lt. GREEN/ red   -   pin 34 at ETACS ECU
Lock Motor lt. green   5wi pin 19, 28 pin plug below fuses
Unlock Motor GREEN/ red   5wi pin 22 at ETACS ECU
Parking Lights+ GREEN / WHITE   +   pin 2, 15 pin plug above fuses
Parking Lights- N/A
Hazards green   -   pin 55 at ETACS ECU
Turn Signal(L) GREEN/ blue   +   pin 8, 15 pin plug above fuses
Turn Signal(R) GREEN/ YELLOW   +   pin 13, 15 pin plug above fuses
Reverse Light RED / blue   +   pin 9, 43 pin plug in driver kick
Door Trigger see notes   -   see notes
Notes: The driver door trigger is lt. green, pin 6, in a 15 pin plug above the fuses. The passenger door is lt. GREEN/ black in pin 65 at the ETACS ECU. Use both wires and diode isolate each.
Dome Supervision GREEN/ orange   -   pin 1, 3 pin plug above fuses
Trunk/Hatch Pin red   -   pin 62 or 37 at ETACS ECU
Notes: It is in pin 62 on the coupes, and in pin 37 on the convertible spyders.
Hood Pin GREEN/ red   -   pin 24 at ETACS ECU
Trunk/Hatch Release GREEN / WHITE   5wi pin 32 at ETACS ECU
Power Sliding Door N/A
Factory Alarm Arm lt. GREEN/ black   -   pin 42 at ETACS ECU
Notes: Meter this wire while turning the key in the driver door key cylinder.
Factory Alarm Disarm orange   -   pin 25 at ETACS ECU
Disarm No Unlock blue/red   -   pin 27 at ETACS ECU
Notes: Meter this wire while turning the key in the hatch/trunk key cylinder.
Tachometer white or BLACK/ white   ac   engine speed detection connector
Notes: The engine speed detection connector is a single pin connector in the fuse/relay box under the hood.
Can also go to one of the ignition coils or the distributor assembly and use the BLACK/ blue or WHITE/ green wire.
Wait to start N/A
Brake Wire GREEN/ orange   +   brake pedal switch
Parking Brake YELLOW /GREEN   -   parking brake switch
Horn Trigger lt. GREEN/ black   -   pin 44 at ETACS ECU
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes: Standard on all models.
jraguilar
Posted: October 17, 2006 at 2:50 PM / IP Logged
thanks for the help it is the 2004
jraguilar
Sunday, May 5, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
