Galaxy 2000RS
Blt79
Member - Posts: 13
Posted: October 19, 2006 at 4:42 PM / IP Logged
I just purchased a galaxy 2000rs for my 87 ford bronco ll. I noticed that the brain has several relays inside, but the manual does not list what these relays are for. Does anyone know what these relays are for? Does anyone know the exact wires needed to connect the remote start? Will I need to add a relay for the clutch bypass?
mario_wireless
Member - Posts: 11
Posted: October 23, 2006 at 1:00 AM / IP Logged
you can find the manual for this system here:http://www.scytek.net/product_galaxy_starter_2000RS-2W-1.html
You will need to bypass the clutch.
Mario
tragik
Copper - Posts: 169
Posted: October 23, 2006 at 12:38 PM / IP Logged
The relays in the brain are for ignition 1 and 2, starter, accessory, parking lights, etc. You shouldn't have to worry about which relay does what, just wire it per the directions and you'll be fine. In fact, the only time you should have to open the brain is if you are upgrading to the 2-way model, or need a nevative parking light output, which you don't on an 87 bronco. You will have to test this, but I think you can take the modules start output directly to the clutch switch to bypass it. I don't recall if that works on an 87, but I think it does. Test it with a dmm first.
Northstart.....or start it your damn self.
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
