Subwoofer Repair Surrounding
do it.
Posted: October 20, 2006 at 12:55 PM / IP Logged
Hey guys, kinda new here but I need some help.
I have a 10in Alpine Type R subwoofer and the rubber surrounding on top of the subwoofer, the outer ring that holds the cone and the sub together has come unglued from the cone. Sorry for my bad terminology but this is the rubber surrounding you can see on top of the sub that holds it all together that moves up and down. Is there a way I can just glue it back on to fix it? Or is there something I can do to fix it.
Any suggestions would be great,
Thx fellas
aznboi3644
Gold - Posts: 2,600
Posted: October 21, 2006 at 10:29 AM / IP Logged
I wouldn't suggest gorilla glue...it needs to be clamped and it expands.
Some GOOP will work...or some thin epoxy
do it.
Posted: October 21, 2006 at 1:30 PM / IP Logged
Ok well I looked around and found some stuff called E6000 that people suggested elitecaraudio.com. They say this stuff works really well.
The problem I have no is how to apply it. I know that it should be clamped down but not really knowing how to do it. I was wondering if I could just spread the glue and and tape it together with some painters tape. Would that be okay?
nubiannupe
Copper - Posts: 55
Posted: October 21, 2006 at 2:06 PM / IP Logged
From personal experience, I wouldn't recommend the "spread-glue-use-tape" method, as you run the risk of damaging the surround. I'd probably do what aznboi3644 recommended and use GOOP. I've used it a while back with a JL10W0 sub I have, and it's STILL running great.
G. Rick (aka; Tha "R")
**Peter North is my idol***
MECP-Certified 1st Class Installer
aznboi3644
Gold - Posts: 2,600
Posted: October 21, 2006 at 6:23 PM / IP Logged
lol I don't think tape is gonna be enough pressure to make it a good bond
aznboi3644
Gold - Posts: 2,600
Posted: October 22, 2006 at 1:40 AM / IP Logged
well you could easily scuff it by taping off the cone that isn't going to be connected to the surround
jvillefinest
Copper - Posts: 255
Posted: October 22, 2006 at 11:22 AM / IP Logged
had the same crap happen to my type R 15s.....frustratings situation...good luck!
2007 Acura TSX
SQ setup in the works
aznboi3644
Gold - Posts: 2,600
Posted: October 22, 2006 at 12:03 PM / IP Logged
Thats when stitched surrounds would help
do it.
Posted: October 22, 2006 at 10:49 PM / IP Logged
yea, this is whats going on with my type r 10's.
This seems to happen with a lot of ppl w/ type r's
Sunday, May 5, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
