HF 850 thru factory speakers
jeffwhiteman
Copper - Posts: 124
Posted: October 20, 2006 at 3:16 PM / IP Logged
I have a 03 Nissan Xtera (not bose system) and want to install moto hf850 or ihf1000 thru factory speakers. i am an installer,but am not familiar with bluetooth radio integration without using an aftermarket harness. i do know the pinout for the factory nissan harness.
nyvr6
Member - Posts: 28
Posted: October 20, 2006 at 5:41 PM / IP Logged
You can tap into one speaker but you ween need a factory mute and I dont think Nissans are equipped with that. If so A DPDT relay triggered by the mute to open up output from radio and redirect from output of either 850 or 1000 by the way use the 1000 voice acctivation works great and the contact list.
nyvr6
Member - Posts: 28
Posted: October 20, 2006 at 5:49 PM / IP Logged
you can also just turn down the stereo when you make or recieve a call still need a realy though.
jeffwhiteman
Copper - Posts: 124
Posted: October 22, 2006 at 11:53 AM / IP Logged
thanks. i figured as much but i was hopeing that there was some trick. Do the parrot kits offer a better solution?
You can vote in polls in this forum
Friday, May 3, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
