1997 Montero Sport engine noise
brianh
Silver - Posts: 518
Posted: January 22, 2003 at 11:08 AM / IP Logged
I installed a sony cd player in this vehicle and there is a little engine noise coming through the radio when the engine is on.  The cd player is clear as a bell.  There is no noise when the engine is off.   I have run a new ground wire to the passanger kick.  I have even tried a isolation trasnformer from Radio Shack.  Nothing seems to help.  Is there somthing that I am missing?  I have even seperated the power wires from the speaker wires at the back of the unit.  Any help to get rid of this noise will be much appreciated.  Thanks in advance.  Brian
haemphyst
Platinum - Posts: 5,059
Posted: January 22, 2003 at 2:09 PM / IP Logged
It is likely that it is not alternator noise, but it really IS engine noise.  Most likely it is coming from your spark plugs or spark plug wires.  How old are these items?  Try replacing the wires, and/or replacing the plugs with resistor types.  Do not skimp on the wires, especially, USE THE OEM ONES!  I have always had good luck with ND or NGK plugs, and they are most likely the recommended plug for your Mitsu.  Avoid Champion and ACDelco, I have almost always had bad luck with them.
brianh
Silver - Posts: 518
Posted: January 22, 2003 at 3:54 PM / IP Logged
Thanks for the info.  I will give it a try.  Brian
Sunday, October 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
