what gauge wires to use
colorblindsam
Member - Posts: 6
Posted: November 02, 2006 at 1:05 PM / IP Logged
i was just wondering if anyone could give me a general idea of what gauge wires to use for the power and ground for a given sized amp. I have a 1000w amp and 2 400w subs, but im not sure if i should go with 4 or 8 gauge wiring for the power and ground. Wasnt sure if it's not that big of a deal or if it could end up messing the amp and subs up. Any help would be appreciated.
DYohn
Moderator - Posts: 10,741
Posted: November 02, 2006 at 1:09 PM / IP Logged
Check the Power and Ground link on the left column of the forum.
jvillefinest
Copper - Posts: 255
Posted: November 02, 2006 at 1:20 PM / IP Logged
another rule of thumb i always use, is give the amp the largest it can handle. if it can accept 4ga give it 4. Same with speaker wire from the amp to the sub. as large as i can be...maybe thats just me...
2007 Acura TSX
SQ setup in the works
colorblindsam
Member - Posts: 6
Posted: November 02, 2006 at 2:34 PM / IP Logged
so using 4 gauge should work just fine? and i remember reading  somwhere that ur ground should always be the same size if not bigger than ur power wire, is that true or just petty non-sensical irritance :) and thanks again for all the help guys
DYohn
Posted: November 02, 2006 at 3:28 PM / IP Logged
Yes, your power and ground must be the same size as both will carry the same amount of current.
colorblindsam
Member - Posts: 6
Posted: November 02, 2006 at 3:30 PM / IP Logged
aight, glad u told me that, this amp wiring kit i got had 4 gauge for the power wire and 8 gauge for the ground....dont know why they did that but thanks again for the help
aznboi3644
Gold - Posts: 2,600
Posted: November 02, 2006 at 3:43 PM / IP Logged
Um...wierd. What amp and kit did you buy?? Most good kits have same power and ground.
Monday, May 20, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
