2006 Nissan Frontier Alarm/Remote Start Wiring
Welcome Guest :)
solartech
Member -
Posted: November 03, 2006 at 3:59 PM / IP Logged
Hi, i need the wire codes for a nissan Frontier asap, thanks
Solartech Window Tinting & Electronics Inc.
KarTuneMan
Platinum -
Posted: November 03, 2006 at 6:29 PM / IP Logged
Wire/Function | Colour | Location/Description | Polarity |
PASSIVE ANTI-THEFT | YES | TRANSPONDER | SEE NOTES |
12 VOLTS | Green | Ignition switch harness | + |
IGNITION | WHITE/ green | Ignition switch harness | + |
ACCESSORY | Red | Ignition switch harness | + |
ACCESSORY 2 | GREEN/ YELLOW | Ignition switch harness | + |
STARTER | BLACK / YELLOW | Ignition switch harness | + |
STARTER 2 | Lt.green | Ignition switch harness | + |
KEY SENSE | Black | Ignition switch harness | + |
TACH SIGNAL | Black | Pin-2 on ECM at back of center console | AC |
FUEL INJECTOR | Opposite from Red | At any injector on engine | AC |
LOCK | GREEN/ purple | Driver kick panel | - |
UNLOCK | WHITE/ green | Driver kick panel | - |
DOORPIN | SEE NOTE | BCM on right of steering column | - |
| | driver door- Gray, Front passenger door- Lt. green, Rear left door- Pink, Rear right door- Blue, |
FACTORY ARM | Lt.blue | Driver kick panel | - |
FACTORY DISARM | RED / white | Driver kick panel | - |
BRAKESWITCH | Yellow | At switch above brake pedal | + |
PARKLIGHTS | Gray | Driver kick panel | + |
HAND BRAKE | Green | Parking brake switch | - |
HORN | Brown | Steering column | - |
REVERSE LIGHTS | Lt.blue | Driver kick panel | + |
VSS WIRE | Lt.blue | At radio harness | AC |
Available Notes
| PLEASE NOTE: This vehicle is equipped with TRANSPONDER chips in the ignition keys. This system must be bypassed for Remote Starter installation. A keyless bypass module may be available, contact your distributor to find out. If one of these modules is not available to you, see the appropriate security diagram for bypass instructions. |
Thursday, May 9, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
