install starter kill switch
ulyses
Member - Posts: 16
Posted: January 23, 2003 at 10:33 PM / IP Logged
hello, i whant to istall a starter kill switch. i need to know the wiring for the 2001 f-150 5.4l 4x4 model. can any body help with that info. thanks.
Sound Pressure
Silver - Posts: 711
Posted: January 23, 2003 at 10:39 PM / IP Logged
Sound Pressure
Silver - Posts: 711
Posted: January 23, 2003 at 10:40 PM / IP Logged
https://www.the12volt.com/relays/page2.asp
Sound Pressure
ulyses
Member - Posts: 16
Posted: January 24, 2003 at 9:08 AM / IP Logged
sound pressure, hello again, where is the ignition wiring harness located,in the vehicle?
Sound Pressure
Silver - Posts: 711
Posted: January 24, 2003 at 10:26 PM / IP Logged
Once you take off that bottom dash off you should see the wiring leading up the steering colum.
Sound Pressure
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
