2001 Ford Taurus SES Stereo Wiring
Welcome Guest :)
kpedx
Member -
Posted: November 12, 2006 at 3:35 PM / IP Logged
need a stereo wiring diagram for a 2001 ford taurus ses, the diagram i found here doesnt match up with my wires
KarTuneMan
Platinum -
Posted: November 12, 2006 at 11:49 PM / IP Logged
| +12V DC Battery(Constant) | RED / yellow | Control unit in left side of luggage compartment | 117 | 20 amp | Junction box in front center of engine compt. |
| Switched Accessory | RED / orange | In-line with the starter relay | 127 | 5 amp | Junction box in front center of engine compt. |
| Ground | BLACK/ lt.green | |
| Power Antenna | RED / pink | |
| Remote Turn On(output) | BROWN / orange | Pin 8 of CD changer. Also light GREEN/ black between rear control unit (C388B-2) and front panel (pin 4). |
| Left Front + | ORANGE / lt.green | |
| Left Front - | Lt.blue/white | |
| Right Front + | WHITE/ lt.green | |
| Right Front - | Dk.GREEN/ orange | |
| Left Rear + | Grey/lt.blue | |
| Left Rear - | Tan / YELLOW | |
| Right Rear + | ORANGE / red | |
| Right Rear - | BROWN / pink | |
AT SPEAKERS | |
| Wire Function | Color | Note |
| Left Front Tweeter + | ORANGE / lt.green | If equipped |
| Left Front Tweeter - | Lt.blue/white | If equipped |
| Right Front Tweeter + | WHITE/ lt.green | If equipped |
| Right Front Tweeter - | Dk.GREEN/ orange | If equipped |
Available Notes | |
| Information listed in the harness section refers (in this case) to the rear control unit in left side of the luggage compartment. INTEGRATED CONTROL PANEL has WHITE/ red for battery input (pin 11), with fuse no. 216 of 15 amps, BLACK/ pink for acc. power (pin 6), with fuse no. 211 of 15 amps, RED / yellow for hot in start or run (pin 16), with fuse no. 227 of 10 amps; these fuses are in the central junction box. AUDIO connections between the integrated control panel (front) and the rear control unit (rear) are as follows: R+ dark blue/white wire between pin 9 front & pin C388B-7 rear R- gray wire between pin 19 front & pin C388B-20 rear L+ BROWN / light green wire between pin 20 front & pin C388B-6 rear L- WHITE/ pink wire between pin 10 front & pin C388B-19 rear |
kpedx
Member -
Posted: November 13, 2006 at 2:48 AM / IP Logged
thanks a bunch man, and if you dont mind me asking, were did you find this?
Friday, October 9, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
