RSX 3.5 Remote Start Not Working
rraasch04
Posted: November 13, 2006 at 10:34 PM / IP Logged
I installed a Clifford RSX 3.5 about a year ago and everything was working fine until today. When I try the remote start the interior/exterior lights flash and I can hear the module/relays going but does not even turn the engine. Any ideas? Fuse/Relay? Thanks!
rraasch04
Posted: November 13, 2006 at 10:44 PM / IP Logged
ah yes i forgot to mention that i did check the 7 wire harness and fuses... and tach wire...
start25
Copper - Posts: 114
Posted: November 14, 2006 at 12:27 AM / IP Logged
I have the same problem on 2000 Malibu...don't know what went wrong yet....
qdaddy
Copper - Posts: 133
Posted: November 14, 2006 at 1:42 AM / IP Logged
relearn the tach if you have had new batt installed or any service done to your vehicle need to relearn tach also does it flash lights to start then turns back off and does the dash lights power up as if ignition is on then turns off or does not turn key at all jus flash lightsRSX 3.5 Remote Start Not Working -- posted image.
