06 Honda Pilot Issues
Most Wanted
Member - Posts: 27
Posted: November 18, 2006 at 7:51 PM / IP Logged
Wow, Talk about an issue.
Cust Drops off car, Drive into bay, Start install. Finish Install, Program Module, Program tach, remove key.
Key will not work in Vehicle anymore, Wont turn ignition or anything. Im stumped, Pulled what i could apart and customer is understanding, What could of went wrong?
Chris Luongo
Platinum - Posts: 3,746
Posted: November 18, 2006 at 8:55 PM / IP Logged
More details needed.
Key won't physicall turn, or turns but does not power up the engine and accessories?
Does the remote start work?
Most Wanted
Member - Posts: 27
Posted: November 18, 2006 at 9:13 PM / IP Logged
Key will not turn, Its acting like its the wrong key.  Remote start works fine, No issues there. Just will not unlock steering, Or anything.  Im Stumped.  Always happens to friends cars, i swear.  I guess off to honda on monday.  It also seems to me its a mechanical issue. From what ive read the immobiliser does not lock up the ignition
lsondubz
Copper - Posts: 193
Posted: November 19, 2006 at 11:32 AM / IP Logged
Did you try another key just for kicks? Also, check out your transponder ring, I have wrapped some too tight and the key would be hard to turn the ignition...Nothing from the electronics can really make a tumbler fail, some of the older fords had problems lining up,I remember it was very common in mustangs so look down the cylinder and make sure its lined up too..If the actual tumbler is locked up, it will have to be replaced.
Chris Luongo
Posted: November 19, 2006 at 3:49 PM / IP Logged
Have you tried turning the steering wheel back and forth while trying to turn the key?
Maybe the wheel was turned hard to one side when the car was shut off, and now the steering wheel lock is stressed too tightly to allow you to turn the key.
Also, try unlocking the doors or tailgate with the key, to verify that you do indeed have the correct key for the car.
Most Wanted
Member - Posts: 27
Posted: November 19, 2006 at 4:39 PM / IP Logged
Tried the valet key and the other key. Im stumped, It's going to the dealer in the am.
The first thing i tried was turning the wheel, Pressing the break, Dancing around in my underwear. No Go.
Also i didn't use a U, i used a Pkh3, So nothing to wrap around.
Thank god, It's a friend that Understands this doodie happens.  Now i get to deal with the honda dealer in the am. I already know there gonna say well we cant touch it and you voided your warranty by installing your remote start, then ill ask how they sell them for 599 and if they void the warranty?
lsondubz
Copper - Posts: 193
Posted: November 19, 2006 at 5:26 PM / IP Logged
They cant void it unless the remote start is pinpointed as the damage of the remote start...
Most Wanted
Member - Posts: 27
Posted: November 19, 2006 at 6:28 PM / IP Logged
Yea i know and understand that. Have you ever dealt with a dealer Service Dept.
green6767
Copper - Posts: 209
Posted: November 19, 2006 at 8:28 PM / IP Logged
OK, I work at a Honda Dealership. I have had this problem before, it sounds like its just locked up really bad. This may sound incorrect but its not, you need to turn the key really hard. Seriously....it works. It may help to turn the steering wheel while doing it, but the Pilots especially have a tendency to do this. It will almost feel like you're going to break the key. Use common sense though man, dont grab the key with a pliers and crank on it or anything....it just needs a little force. If that honestly doesn't work and you think by your feel that it just wont turn without damaging something, you may have other issues.
Shaun, we are the same height, that is neat!
12V Installation Technician for Honda, Dodge, Chrysler, Toyota and Jeep.
Most Wanted
Member - Posts: 27
Posted: November 19, 2006 at 8:37 PM / IP Logged
is there any electronics in the column that are activated???
Ive already tried turning it, i think i can feel the plastic key getting loose.  So its a know problem, thats good to know.
