04 silverado 557gw problems, Superchips
i_2003i
Posted: November 24, 2006 at 12:24 PM / IP Logged
I am installing an autostart using the Dei 557GW databus module on a 04 Silverado HD with the 6.0 liter gas engine equiped with a superchips reprogramer.
    Everything works, the locks, door trigger, and remote start.. the problem is when i remote start the truck, the engine light will turn on and the truck will not shift out of 2nd gear. If i kill it with the brake and start with the key, it works perfectly. I have installed many of these and they all work just fine, i tested the obd II system with the truck autostarted and it gives me a transmission line pressure error. I think it is interfering with the superchip.. has anyone had these problems before? Please help asap. thanks
xtremej
Gold - Posts: 1,440
Posted: November 24, 2006 at 12:37 PM / IP Logged
It sounds as if your are not powering up the second ignition wire. I believe its white in the ignition harness, verify with a  meter and this will correct your problem.
xtremej
Gold - Posts: 1,440
Posted: November 24, 2006 at 12:38 PM / IP Logged
I assumed you ment 457gw as your module also04 silverado 557gw problems, Superchips -- posted image..
Monday, February 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
