Dimm or illum wire?
badiroc
Posted: November 25, 2006 at 9:15 AM / IP Logged
Installing a Pioneer dehp47dh head unit in a grand am. I want the head unit to dim with the dash lights. Problem is i only have an illumination wire off the head unit but a dimm and illimination wire off the harness. My question is if i hook up the dimm will it work as i want it to? Leaving the illumination wire disconnected or do you hook them both together?
danieljaluise
Copper - Posts: 125
Posted: November 25, 2006 at 10:57 AM / IP Logged
you want to connect the illumination wire from the head unit to the illumination wire on the harness. Don't use the dimm wire at all, and don't hook them together.
The illumination wire should show 12+ volts only when you turn the healdights or parking lights on.
It's not possible to have the pioneer dim variably like the stock one does, it only has two levels of brightness....full, and dim when you turn the head lights on.
badiroc
Posted: November 25, 2006 at 11:04 AM / IP Logged
Thank you. Seems to be a lot of people out there with the same question. Maybe Pioneer should adress this in the installation manual.
master5
Silver - Posts: 1,123
Posted: November 25, 2006 at 6:30 PM / IP Logged
The reason they probably don't address this in the manual is because any qualified installer will know the difference..and the aftermarket harnesses are color coded.
But we all start somewhere and learn as we go.
Basically the dimmer wire is for dimming..the ill lights the backlights since most factory deck use a seperate wire for each function.
since most aftermarket decks that even have an illumination wire only use one..it is assumed to connect to the illimination wire. If the deck had a specific wire for dimer, it would be labled as such.
Sunday, December 21, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
