2000 Honda Civic lock wiring
Scoobyz
Member - Posts: 8
Posted: November 27, 2006 at 2:52 PM / IP Logged
My Dad has just got himself a Honda Civic year 2000 but it's the old Rover style shape, he wants to fit his old alarm that was on his previous car,single wire subaru, I'm after info on the central locking system, wiring colours, is it a single neg pulse system or a two wire job??
Thanks for any help
auex
Platinum - Posts: 5,041
Posted: November 27, 2006 at 3:23 PM / IP Logged
it should be 2 wire negative pulse. check the diagrams section for wire colors.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
thepencil
Gold - Posts: 1,526
Posted: November 27, 2006 at 3:25 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - HONDA / CIVIC / 2000 / Keyless Entry
12volts white    +   ignition harness
Starter BLACK/ white    +   ignition harness or
Notes: In 6 pin white plug behind fuse box
Ignition BLACK / YELLOW    +   ignition harness
Power Lock GREEN / WHITE    -   keyless entry module
Notes: The keyless entry module is white in color, and located in the drivers kick panel.
Power Unlock GREEN/ orange    -   keyless entry module
Lock Motor WHITE/ red      drivers kick panel
Unlock Motor blue/red      drivers kick panel
Parking Lights+ RED / black      keyless entry module
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger lt. GREEN/ red    -   OEM alarm plug
Notes: The OEM alarm plug is to the right side of the steering column. The plug is green.
Dome Supervision same as doors
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Horn Trigger gray    -   OEM alarm plug
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Smart Starter Kill Relays: Not Available
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
Be careful whose advice you buy, but be patient with those who supply it.2000 Honda Civic lock wiring - Last Post -- posted image.
Scoobyz
Member - Posts: 8
Posted: November 28, 2006 at 1:05 PM / IP Logged
Thanks for you replies chaps, he's been out today and got a Haynes manual for the car, it has the full wiring diagram for the C/L circuit, so this has made thing MUCH easier2000 Honda Civic lock wiring - Last Post -- posted image.
Friday, October 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
