instruction's for an omega alarm
camino
Copper - Posts: 54
Posted: January 27, 2003 at 11:51 AM / IP Logged
I'm having a problem with an older model alarm,it is an omega alarm,the thing is,that when you turn on the ignition is making a noise like a warn way type,and when the ignition is turned off to,the systems was in the car when come to do the tinting in the shop that i work,i will thank any help about the programing or how to make that noise go.thanks. hey! jeff i hope you know the answer,i think you know.
el camino
securinu
Silver - Posts: 772
Posted: January 27, 2003 at 5:31 PM / IP Logged
it sounds like the atv has kicked in it . is it chirping 8 times when you turn the key on??? if so then what is going on is that someone in the last 48 hours has coded a remote to the system it is designed to alert the owner if someone unauthorized has coded a new remote.it will stop after 48 hours from the coding.
camino
Copper - Posts: 54
Posted: January 28, 2003 at 12:54 AM / IP Logged
thanks,that really help me,i know  about viper and dei,but this omega alarms nothing,well thanks again.
el camino
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
