2005 GMC Jimmy Remote Start
Welcome Guest :)
frizzo
Member -
Posted: December 04, 2006 at 10:25 PM / IP Logged
Require the wiring info for a 2005 GMC Jimmy 2-Door , Can't find this info anywhere! WOuld it be the same as the 2005 Blazer?
jasondavis05
Copper -
Posted: December 05, 2006 at 12:51 AM / IP Logged
This should be what you need, and yes I think they are the same truck.
12 VOLT CONSTANT | RED (+) and RED / WHITE (+) | IGNITION SWITCH HARNESS | |
STARTER | YELLOW (+) | IGNITION SWITCH HARNESS | |
STARTER 2 | N/A | | |
IGNITION 1 | PINK (+) | IGNITION SWITCH HARNESS | |
IGNITION 2 | WHITE (+) See NOTE *4 | IGNITION SWITCH HARNESS | |
IGNITION 3 | N/A | | |
ACCESSORY /HEATER BLOWER 1 | ORANGE (+) | IGNITION SWITCH HARNESS | |
ACCESSORY /HEATER BLOWER 2 | N/A | | |
KEYSENSE | N/A | | |
PARKING LIGHTS ( - ) | WHITE (-) | @ BCM, LIGHT BLUE Plug, Pin A5, See NOTE *1 | |
PARKING LIGHTS ( + ) | BROWN (+) | @ BCM, LIGHT BLUE Plug, Pin B6, See NOTE *1 | |
POWER LOCK | LIGHT BLUE (TYPE A) | @ BCM, BROWN PLug, Pin A4, See NOTE *1 | |
POWER UNLOCK | WHITE (TYPE A) | @ BCM, BROWN Plug, Pin A3, See NOTE *1 | |
LOCK MOTOR WIRE | GRAY (+) | @ RELAY BLOCK NEXT TO FUSE BOX | |
DOOR TRIGGER | See NOTE *2 | @ BCM, See NOTE *1 | |
DOMELIGHT SUPERVISION | GRAY/BLACK (-) | @ BCM, LIGHT BLUE Plug, Pin A3, See NOTE *1 | |
TRUNK RELEASE | BLACK (-) | @ BCM, PURLPLE, Pin B1 Plug, See NOTE *1 | |
SLIDING POWER DOOR | N/A | | |
HORN | BLACK (-) | @ BCM, BROWN Plug, Pin A9, See NOTE *1 | |
TACH | WHITE | @ PCM, GREEN Plug, Pin 10, See NOTE *3 | |
WAIT TO START LIGHT | N/A | | |
BRAKE | WHITE (+) | @ SWITCH ABOVE BRAKE PEDAL | |
FACTORY ALARM DISARM | LIGHT GREEN (-) | @ BCM, PURPLE Plug, Pin B3, See NOTE *1 | |
ANTI-THEFT | YELLOW (+), ORANGE / BLACK (-) and RED / WHITE (Not used) | GM's PASSLOCK 2 System, these wires exit the Ignition Switch Tumbler together and are in the Main Ignition Switch Harness in the Column. |
Sunday, April 28, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
