03 silverado crimestopper
bry_gordan
Member - Posts: 34
Posted: December 08, 2006 at 9:10 PM / IP Logged
instaled 1303 dp w/ a gmsl 2 lights and door locks work hit start and all it does is flash lights
Brian Gordan
prdjr165
Copper - Posts: 293
Posted: December 08, 2006 at 10:48 PM / IP Logged
It sounds like either the hoodpin wire(gray)is grounded or the brake switch wire(purple)is seeing 12volts,either one of those will keep the vehicle from cranking.
ziggyb222
Silver - Posts: 593
Posted: December 09, 2006 at 5:00 AM / IP Logged
Also make sure the both 12 volt power wires(red) are getting constant 12 volts.
bry_gordan
Member - Posts: 34
Posted: December 09, 2006 at 7:49 AM / IP Logged
03 silverado crimestopper 1303dp2 w/ gmsl2  used 2 direrent sys. and it still starts and runs once fine but when you try it a second time it flashes the lights 5 times unplug it reprogram the gmsl2 same thang what am i doing wrong
Brian Gordan
barnold
Posted: December 12, 2006 at 3:05 PM / IP Logged
i had the exact same problem this morning and it was just a bad module 1304 it was...  and if you use a gmsl2 i would  wire it conventional and not use the data link...
reisset
Member - Posts: 38
Posted: December 12, 2006 at 3:32 PM / IP Logged
What is the version of the GM SL2 ???
reisset
Member - Posts: 38
Posted: December 12, 2006 at 3:33 PM / IP Logged
bry_gordan
Member - Posts: 34
Posted: December 14, 2006 at 9:08 AM / IP Logged
i finaly got a hold of the company and the are sending a chip out  that has to be put in the box if you open the cover and it sayes 750 it is not compatable with gmsl2
Brian Gordan
Friday, May 3, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
