2005 mitsubishi montero
Welcome Guest :)
ramiroggenbu
Member -
Posted: December 16, 2006 at 2:11 AM / IP Logged
does anyone have the wiring diagram for a 2005 mitsubishi montero? it is not a sport if that makes a difference.
Thanks for the help
Mike R
rudydapimp
Copper -
Posted: December 16, 2006 at 10:57 AM / IP Logged
12volts | blue/white (40A) | + | ignition harness | Starter | BLACK / YELLOW | + | ignition harness | Second Starter | N/A | | | Ignition | blue/black | + | ignition harness | Second Ignition | N/A | | | Third Ignition | N/A | | | Accessory | blue/red | + | ignition harness | Second Accessory | blue / YELLOW | + | ignition harness | Keysense | RED / blue | | ign harn or ETACS ECU, pin 26 | Notes: This wire rests at ground with the key out of the ignition cylinder, and goes to an open circuit when the key is inserted.The ETACS ECU is attached to the back of the fuse box. | Power Lock | lt. GREEN/ wht to lt. GREEN/ red | - | ETACS ECU, pin 53 | Notes: The ETACS ECU is attached to the back of the fuse box. | Power Unlock | BROWN / white | - | ETACS ECU, pin 54 | Notes: The ETACS ECU is attached to the back of the fuse box. | Lock Motor | blue/black | 5wi | 15 pin plug below fuses, pin 8 | Unlock Motor | blue/red | 5wi | 13 pin plug above fuses, pin 13 | Parking Lights+ | GREEN/ orange or GREEN / WHITE | + | driver kick, harness to rear | Parking Lights- | N/A | | | Hazards | green | - | switch or ETACS ECU, pin 27 | Notes: The ETACS ECU is attached to the back of the fuse box. | Turn Signal(L) | GREEN/ YELLOW | + | 15 pin plug below fuses, pin 7 | Turn Signal(R) | GREEN/ red | + | 15 pin plug below fuses, pin 14 | Reverse Light | RED / green | + | driver kick, harness to rear | Door Trigger | RED / green | - | 15 pin plug below fuses, pin 10 | Dome Supervision | use door trigger wire | | | Trunk/Hatch Pin | common with door trigger wire | | | Hood Pin | blue/black | - | ETACS ECU, pin 48 | Notes: The ETACS ECU is attached to the back of the fuse box. | Trunk/Hatch Release | N/A | | | Power Sliding Door | N/A | | | Factory Alarm Arm | lt. GREEN/ blue to blue | - | ETACS ECU, pin 50 | Notes: Meter this wire while turning the key in the driver door key cylinder.The ETACS ECU is attached to the back of the fuse box. | Factory Alarm Disarm | brown | - | ETACS ECU, pin 52 | Notes: Meter this wire while turning the key in the driver door key cylinder.The ETACS ECU is attached to the back of the fuse box. | Disarm No Unlock | see factory alarm disarm | | | Tachometer | WHITE/ green | ac | engine speed detection connector | Notes: The engine speed detection connector is a 3 pin plug in the fuse/relay box under the hood.Can also go to one of the ignition coils and use the wire that is NOT blue/black or black. | Wait to start | N/A | | | Brake Wire | blue/orange | + | brake pedal switch | Parking Brake | yellow/black | - | parking brake switch or cluster | Horn Trigger | lt. GREEN/ black | - | switch or ETACS ECU, pin 42 | Notes: The ETACS ECU is attached to the back of the fuse box. | Memory Seat 1 | N/A | | | Memory Seat 2 | N/A | | | Memory Seat 3 | N/A | | | Interface Module: | Category:Immobilizer Bypass | Required:Yes | Type:Transponder | Part #: 556UW | Alternate Part1 #: DesignTech 20402 | Alternate Part2 #: DesignTech 29402 | Notes: Standard on all models. |
Saturday, May 18, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
