Neutral Safety, other ways?
rideexileex
Member - Posts: 19
Posted: December 16, 2006 at 4:16 AM / IP Logged
I'm just wondering what other intuitive methods are there for ensuring that a car is in neutral for a remote start. Preferably other than the typical e-brake ground wires that are "suppose" to keep the car from lurching, etc. Anything custom fabricated that would work?
The best I could come up with was installing some type of ring around the shifter, then a spring loaded ring around that, which would loose contact when in neutral and provide a ground, but, it would be a quick victim to mechanical fatigue as it would constantly be moving the springs while shifting.
Let me know what you have seen/done in the past... thanks
KPierson
Platinum - Posts: 3,527
Posted: December 16, 2006 at 10:39 AM / IP Logged
The problem with that is that every car is different.  Every shifter is different, and all the linkage is different.  I don't think it would be possible to come up with one solution that would work on 75% of cars.
Things I've done:
Used OEM NSS switch (Most Nissans have them)
Magnetic switches on the shift linkage itself.  When the car is in N the linkage is in the middle of it's travel, when in first, third, or 5th it's at its far end, and 2nd, 4th, and R it was at it's close end.  So, if the magnets were lined up the car would start.
I've always thought using IR light would be a good way to sense position, but I'm not sure how practical it would be.  You would have to have a place to install it that would only allow the light to pass when the car was in N.  Possibly, use two seperate beams, one on each side of the shifter, and if the detector picks up both beams allow the car to start?
There are also some companies that make an add on 'shutdown' module that requires you to shut the vehicle off in a specific way to allow you to start it back up.
Kevin Pierson
KarTuneMan
Platinum - Posts: 7,056
Posted: December 16, 2006 at 12:56 PM / IP Logged
Don't do anything but install a remote start designed for a manual trans. They are fool proof. NO elusive NUETRAL safety switch needed. And be careful what you ask for here .....the moderators will lock the topic.   FYI.
Evolution-UK
Copper - Posts: 192
Posted: December 16, 2006 at 2:08 PM / IP Logged
I know that directed here in the uk have a unit called the MTM1. It's designed to allow remote start units designed for automatics to work on manual transmittions.
Wednesday, April 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
