2002 Sierra brake and hood input
jweld97
Member - Posts: 17
Posted: December 16, 2006 at 1:07 PM / IP Logged
I am installing a Radiostar Generation R/S and alarm combo into my 2002 Sierra. It will start the truck fine, however it will not kill the engine when you step on the brake or open the hood. The hood pin is connected properly and opens and closes properly. The brake wire is connected properly, too. Any ideas besides a faulty brain? My other question is are the power door locks are + or -? Any help with these issues would be appreciated.
jweld97
Member - Posts: 17
Posted: December 16, 2006 at 1:36 PM / IP Logged
If it helps, I guess the R/S unit is also known as a King Eagle, but I cannot find an info on a manufacturer website. Anyway, thanks in advance for any help.
kgerry
Platinum - Posts: 3,455
Posted: December 16, 2006 at 1:37 PM / IP Logged
did you verify your wires with a meter?   if you cut the hood wire inside the vehicle and grouind it, does the R/S shut down?  if it does, then you have to adjust your switch and the brain is opereating properly..... if you cut the wire going to the brake and apply 12 volts to it does the R/S shut down?  if yes, then you have the wrong wire at the brake... if not then , you may have a bum brain unit.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
jweld97
Member - Posts: 17
Posted: December 16, 2006 at 1:45 PM / IP Logged
Thank you for your response kgerry. I will try it out right away.
splaudio
Copper - Posts: 237
Posted: December 16, 2006 at 4:22 PM / IP Logged
for ur brake wire it is white+ at the brake switch
for hood u must install a hood pin for it to work. and make sure it is grounded good(bolted tight)
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
