Remote start only runs for 1 min.
timaay
Member - Posts: 27
Posted: December 17, 2006 at 1:33 PM / IP Logged
I installed a Compustar 2wss-as in a 94 man tran accord. Everything works, but when remote started the car will only run for a minute or two. I have the switch set to run for 25 minutes. Any ideas?
timaay
Member - Posts: 27
Posted: December 19, 2006 at 6:18 PM / IP Logged
I figured it out. The owner of the car had replaced the stock brake light bulbs with LED bulbs causing the brake light out indicator to turn on. That for some reason caused the unit to shut down the vehicle. Has anyone ever heard of this happening before?
thepencil
Gold - Posts: 1,526
Posted: December 19, 2006 at 6:53 PM / IP Logged
That is a first for me. I don't see how? The unit will only shut down if +12V is detected on the brake line. I would verify the brake wire to be sure. Could be a poor tach detection, that's my guess.
Be careful whose advice you buy, but be patient with those who supply it.Remote start only runs for 1 min. -- posted image.
mobilecustoms
Silver - Posts: 397
Posted: December 19, 2006 at 7:16 PM / IP Logged
ive heard that before
Moderator - Posts: 12,488
Posted: December 20, 2006 at 9:02 AM / IP Logged
I haven't heard that before but have had a problem with a pooor alternator signal causing the vehicle to shut down after 1 minute of running.
swamprat323
Gold - Posts: 1,335
Posted: December 20, 2006 at 10:50 AM / IP Logged
never delt with compustar before, do compustar have a shut down menu liek a lot of other compines. if so that shold be able to tell ya why it is shutign down
Saturday, January 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
