06 chevy aveo door locks
sxyscion
Member - Posts: 6
Posted: December 18, 2006 at 4:33 PM / IP Logged
looking for 2006 chevy aveo power door lock wires.dei and bulldog tech say gray and lt green both i found at the door lock control module on the passenger side kick. the grey unlock wire only works when the doors are already unlocked .the lt green does nothing when a ground is applyed to it .i tried both wires with the door shut. dei tech support says those wires work every time. i even went to the factory alarm module and found the same wires but still no luck. This car has no power door lock switch but has keyless entry built on the ignition key.
Moderator - Posts: 12,488
Posted: December 18, 2006 at 5:52 PM / IP Logged
LOCK Gray/Green At doorlock module
UNLOCK YELLOW /GREEN At doorlock module
Door lock module is under the center console infront of the hand brake.
mikvot
Gold - Posts: 1,043
Posted: December 19, 2006 at 8:14 PM / IP Logged
nice................or same colors as above but at connector  by blower motor on pass side.
Saturday, May 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
