2006 Civic remote start
jprichard
Member - Posts: 8
Posted: December 23, 2006 at 8:47 PM / IP Logged
Has anyone installed a remote starter in a 2006 Honda Civic? If so, is there anything unusual about this task or is it pretty much like the previous years, like 2000 and up?
Twelvoltz
Platinum - Posts: 2,384
Posted: December 23, 2006 at 8:53 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - HONDA / CIVIC / 2006 / Remote Start
[PRINT THIS PAGE]
12volts      white (50A)       +       ignition harness
Starter      yellow       +       ignition harness
Second Starter      N/A
Ignition      blue       +       ignition harness
Second Ignition      N/A
Third Ignition      N/A
Accessory      orange       +       ignition harness
Second Accessory      red       +       ignition harness
Keysense      pink       -       ignition harness
Power Lock      green       -       dr kick or MICU, 34 pin plug, pin 28
Notes: The MICU (Multiplex Integrated Control Unit) is part of the fuse/relay box under the driver side dash. It has two plugs on the back of the fuse/relay box.
On the 4 door models, this wires changes from blue to green.
Power Unlock      gray       -       dr kick or MICU, 34 pin plug, pin 27
Lock Motor      blue       5wi      DKP or fuse box, rear 14 pin plug
Unlock Motor      yellow       5wi      DKP or fuse box, rear 14 pin plug
Parking Lights+      red       +       dr kick or fuse box, top 42 pin plug
Parking Lights-      gray or red       -       switch or MICU, 20 pin plug, pin 13
Hazards      green       +       switch or fuse box, rear 16 pin plug
Turn Signal(L)      blue       +       dr kick or fuse box, top 42 pin plug
Turn Signal(R)      brown       +       dr kick or fuse box, top 42 pin plug
Reverse Light      brown (4dr) or purple (2dr)       +       dr kick or fuse box, top 42 pin plug
Door Trigger      see notes       -       ea kick or fuse box, top 42 pin plug
Notes: The LF door is green in pin 37. The RF door is lt. green in pin 3. The LR door is brown in pin 17. The RR door is gray in pin 2. Use all four wires and diode isolate each.
Dome Supervision      pink       -       fuse box, rear 8 pin plug
Notes: Also found in a plug attached to the bottom of the fuse box.
Trunk/Hatch Pin      blue       -       dr kick or fuse box, top 42 pin plug
Hood Pin      lt. blue       -       pin sw or fuse box, mid 21 pin plug
Trunk/Hatch Release      green       +       dr kick or fuse box, top 42 pin plug
Power Sliding Door      N/A
Factory Alarm Arm      orange       -       dr kick or MICU, 34 pin plug, pin 32
Notes: Meter this wire while turning the key in the driver door key cylinder.
On the 4 door models, this wire changes from pink to orange.
Factory Alarm Disarm      brown       -       dr kick or MICU, 34 pin plug, pin 31
Disarm No Unlock      see factory alarm disarm
Tachometer      NOT blk/wht, black or yel/blk       ac       any ignition coil or fuel injector
Wait to start      N/A
Brake Wire      lt. green       +       switch or fuse box, top 42 pin plug
Parking Brake      orange (4dr) or lt. blue (2dr)      -       parking brake switch
Horn Trigger      orange       -       switch or fuse box, rear 16 pin plug
Memory Seat 1      N/A
Memory Seat 2      N/A
Memory Seat 3      N/A
Interface Module:      Category:
Immobilizer Bypass      Required:
Yes      Type:
Transponder
Part #: 1100F
Alternate Part1 #: 1100X
Alternate Part2 #: 556UW
Alternate Part3 #: DesignTech 20402
Alternate Part4 #: DesignTech 29402
Notes: Standard on all models. When using the 1100F or 1100X, a software change to 1100HKD is needed.
Smart Starter Kill Relays: Not Available
warning
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
mikvot
Gold - Posts: 1,043
Posted: December 23, 2006 at 9:07 PM / IP Logged
funny you should ask, just did one today........slammer
jprichard
Member - Posts: 8
Posted: December 23, 2006 at 9:12 PM / IP Logged
Slammer ??? is that good or bad? hehe
profuse007
Gold - Posts: 2,015
Posted: December 23, 2006 at 9:20 PM / IP Logged
he meant piece of cake. kinda bad diction... lol
Houston,TX
mikvot
Gold - Posts: 1,043
Posted: December 23, 2006 at 9:48 PM / IP Logged
yeah, that wat i meant..........o, you gonna make fun of my spelling now........lol
Wednesday, February 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
