viper 1000, 2006 MK 7 Transit van
profuse007
Gold - Posts: 2,015
Posted: December 31, 2006 at 1:51 PM / IP Logged
the module pulsing the parking light, so no constant output. FYI, parking light is diff from signal light.
check in relay section for converting from pulsing to constant using a relay, couple resistors, and a capacitor.
Houston,TX
the viking
Member - Posts: 13
Posted: December 31, 2006 at 3:06 PM / IP Logged
Thanks for your reply I will take a look over on the relay section.  so what are your parkig lights ?
Cheers
Ravendarat
Platinum - Posts: 2,806
Posted: December 31, 2006 at 3:56 PM / IP Logged
Parking lights are the indicators on the vehicle that come on to make the corners of the vehicles visible when the night time lights are turned on. They are active with the headlight swith normally in the first on position before the headlights themselves turn  on in the number 2 position. This wire can normally be found at the head light switch itself or at a relay under the hood.
the viking
Member - Posts: 13
Posted: December 31, 2006 at 4:03 PM / IP Logged
That explains what parking lights are . Here in the UK we call these lights side lights .
Ravendarat
Posted: December 31, 2006 at 5:23 PM / IP Logged
Makes complete sense
