radio shuting off cant figure it out?
rx117
Member - Posts: 12
Posted: January 03, 2007 at 8:05 PM / IP Logged
I work at sound advice, I installed a JBL 6 channel amp and a pioner deck. customer came back saying the radio shuts off randomly, it shuts off like you held the source button and turned it off, clock shows up and keeps memory. I swaped the radio didnt help, I thought maybe volt. was dropping on acc wire so I ran an 8 gauge wire from the batt to behind the radio Y'd it off to the constant and put a realy on for the acc still doing it. I was thinking maybe ground but if it lost its ground it would loose memory correct?
any other suggestions???
thanks
mike12volt
Copper - Posts: 98
Posted: January 03, 2007 at 8:15 PM / IP Logged
What model Pioneer deck? What kind of car?make/model/year, When excactly is the radio turns off by itself? It would realy help for replies.
rx117
Member - Posts: 12
Posted: January 03, 2007 at 8:23 PM / IP Logged
sorry mitsubishi eclipse mid 90's not sure exact year. pioneer DEH-P6800MP  radio shuts off randomly just when it wants its done it with it playing loudly and turned all the way down, light on and lights off,  just seems to do it when it wants to.
mike12volt
Copper - Posts: 98
Posted: January 03, 2007 at 8:28 PM / IP Logged
Does it happen while driving or not?
mike12volt
Copper - Posts: 98
Posted: January 03, 2007 at 8:51 PM / IP Logged
Very siple, I would pull the deck out and test it by hooking-up ground and acc with constant12v together. If it still does it, it is the deck, if not I would look into a acc connection at the car harness and whatever you have hooked-up to the deck. Most likely it would be the connections between harnes and deck being interrupted.
Saturday, July 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
