Engine Noise with 640 watt amp
aznboi3644
Gold - Posts: 2,600
Posted: January 07, 2007 at 5:44 PM / IP Logged
Um...try regrounding your head unit...make a new solid ground for it...bare metal.
And I would suggest rather a nut and a bolt for a ground and sand away all paint to clean bare metal
gankstaflash
Member - Posts: 35
Posted: January 07, 2007 at 6:39 PM / IP Logged
Do you think its the way I connected the power to the amp?
I just connected the wire directly from the battery to the amp. Is this the right way to do it?
DYohn
Platinum - Posts: 10,741
Posted: January 07, 2007 at 8:25 PM / IP Logged
I suggest reading the grounding sticky threads at the top of the forum listing.  Those threads are there to help with thse sorts of problems since they come up over and over again.  Please read them, then come back and ask questions if you don't understand.
gankstaflash
Member - Posts: 35
Posted: January 08, 2007 at 1:10 AM / IP Logged
Sorry, this might be a stupid question, but what is a HU?
killer sonata
Silver - Posts: 718
Posted: January 08, 2007 at 8:47 AM / IP Logged
HU = head unit (your cd player)
ricoshay
Copper - Posts: 67
Posted: January 08, 2007 at 12:17 PM / IP Logged
you could also have a bad ground within your CD player.  Pioneers decks have been notorius for this.
gankstaflash
Member - Posts: 35
Posted: January 08, 2007 at 4:40 PM / IP Logged
Yes, my cd player might hav a bad ground :(. I just connected all the wires from my factory toyota HU Engine Noise with 640 watt amp - Page 2 -- posted image. to my new panasonic one.
I asked a friend and they said to test the RCA cables with a mp3 player or something like that. I used a 3.5mm jack to RCA(female) converter, and then used the RCA cables which I used to connect my HU to Amp. I turned on the car and there was no whine! Engine Noise with 640 watt amp - Page 2 -- posted image..
So do think its my HU ground? Btw: It's a Panasonic CQ-C7300W
gankstaflash
Member - Posts: 35
Posted: January 09, 2007 at 12:30 AM / IP Logged
ok, I re-grounded my head unit to where my amp was grounded but the noise still comes! ARGH!!!
I have sanded it VERY well, its bare metal.
I used gold plated connectors and a nut and bolt.
Please Help Me!
geepherder
Platinum - Posts: 3,668
Posted: January 09, 2007 at 6:55 PM / IP Logged
You can also try grounding the outer portion of the rca's at the deck/amp.
DYohn
Posted: January 09, 2007 at 7:19 PM / IP Logged
Did you read the grounding sticky threads?  Did you measure your amplifier ground return resistance?
Page of 3
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
