1993 infiniti q45 factory alarm
r2d97
Member - Posts: 31
Posted: January 07, 2007 at 9:22 AM / IP Logged
I am going to be installing a 2w900fmas in my brothers 93 infiniti 45 today and was wondering about the factory alarm. How do I disable this so that it does not interfere with this system???
KarTuneMan
Platinum - Posts: 7,056
Posted: January 08, 2007 at 8:51 AM / IP Logged
Here is a sheet tha shows the compustar wire and color and plug/pin numbers, and where they connect to your car.
Wire/FunctionCM3000ColourLocation/DescriptionPolarity
 12 VOLTS RED (CN1) WHITE/ black Ignition harness
 IGNITION GREEN (CN1) BLACK/ white Ignition harness
 ACCESSORY WHITE (CN1) Blue Ignition harness
 STARTER YELLOW (CN1)  BLACK/ red Ignition harness
 KEY SENSE  Pink/blue Ignition harness
 TACH SIGNAL YELLOW/BLACK (CN3) Blue/green At module in pass. Kickpanel
 LOCK BLUE/BLACK (CN4) Pink/black In driver's kickpanel
 UNLOCK BLUE (CN4) ORANGE / blue In driver's kickpanel
 DOORPIN RED / WHITE(-) or RED(+) (CN3) GREEN/ YELLOW At alarm module
This module is located behind the glove compartment.
 HOODPIN GRAY/BLACK (CN3) BLACK/ pink At alarm module
 TRUNK PIN VIOLET/BLACK (CN3) RED / white At alarm module
 TRUNK RELEASE VIOLET/WHITE (-) (CN4) Purple At release switch in dash
 FACTORY ARM ORANGE (CN5) Yellow At alarm module
 FACTORY DISARM ORANGE / WHITE (CN5) Lt.blue At alarm module
 BRAKESWITCH LT.BLUE/WHITE (CN3) RED / green At switch above brake pedal
 PARKLIGHTS GREEN / WHITE (+) (CN1) or (-) (CN2) RED / yellow In driver's kickpanel
 HORN WHITE (-) (CN5) WHITE/ green At steering column
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
