2006 Hyundia Elantra remote start
tkur
Member - Posts: 27
Posted: January 08, 2007 at 9:03 AM / IP Logged
Wiring for remote start.
KarTuneMan
Platinum - Posts: 7,056
Posted: January 08, 2007 at 12:07 PM / IP Logged
ONLY IF YOU ASK NICELY.........
Wire/Function Colour Location/Description Polarity
 12 VOLTS Red or Pink Ignition switch harness   +
 IGNITION Orange Ignition switch harness   +
 ACCESSORY Green Ignition switch harness   +
 STARTER White Ignition switch harness   +
 KEY SENSE Blue/orange or Green At steering column   +
 TACH SIGNAL White Pin-47 on ECM above DKP   AC
 You can also use the WHITE or YELLOW at the coil pack on the left side of the engine. Here the wire provides a 2 cylinder signal. (see the photo)
 FUEL INJECTOR blue on top of engine   AC
 LOCK Pink or Yellow At ETACS module behind ashtray   -
 This vehicle is also available with a central locking system (no motor in driver's door). These vehicle will require the addition of an actuator to the driver's door for doorlock control.
 UNLOCK Yellow/orange At ETACS module behind ashtray   -
 DOORPIN Yellow At ETACS module behind ashtray   -
 HOODPIN GREEN/ black At ETACS module behind ashtray   -
 May not be present on models without factory alarm.
 TRUNK PIN GREEN/ black At ETACS module behind ashtray   -
 FACTORY ARM Through OEM remote only
 There is no external arm disarm capability. The alarm will however disarm on remote start automatically id armed.
 FACTORY DISARM Through OEM remote only
KarTuneMan
Posted: January 08, 2007 at 12:12 PM / IP Logged
BRAKESWITCH White At switch above brake pedal   +
 PARKLIGHTS GREEN/ orange On fusebox below driver's side dash   +
 HAND BRAKE Blue In driver's kickpanel   -
 HORN Red At steering column   -
 CLUTCH SWITCH Red At top connector on clutch pedal   TYPE 1
 DRIVER WINDOW UP Brown At master switch in driver's door   REV POL
 DRIVER WINDOW DOWN Orange At master switch in driver's door   REV POL
 PASSENGER WINDOW UP Green In harness from driver's door - DKP   REV POL
 PASSENGER WINDOW DOWN Gray In harness from driver's door - DKP   REV POL
 LEFT REAR WINDOW UP Pink In harness from driver's door - DKP   REV POL
 LEFT REAR WINDOW DOWN Blue In harness from driver's door - DKP   REV POL
 RIGHT REAR WINDOW UP Brown In harness from driver's door - DKP   REV POL
 RIGHT REAR WINDOW DOWN White In harness from driver's door - DKP   REV POL
 HEADLIGHTS White At light switch   -
 VSS WIRE Gray/orange At Cruise module below radio or inst. Cluster
tkur
Member - Posts: 27
Posted: January 10, 2007 at 8:46 AM / IP Logged
Thanks Kar!  Now I can install the xmas present I got for my wife.
Wednesday, May 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
